Bearing ID increases or decreases w.r.t. temperature
I posted this query in bearings section. I feel this is the right forum to post this query.
Hi all,
This is a general question.
When we heat a cylindrical bar, it expands in Length, Outer diameter and
Inner diameter.
Now i have two queries.
1) We press fit a sleeve bearing made of steel with a tin babit coating on
to an  aluminum endshield.   When this assembly is heated
will the ID of the bearing increase or decrease. Our vendor has sent us
data with Id of the diameter to be decreasing when the assembly is heated.
2) If all the dimensions are increasing, where is the extra volume coming
from?
Kamalakar
RE: Bearing ID increases or decreases w.r.t. temperature
2) potential energy in the inter atomic bonds
Cheers
Greg Locock
