Drainage Design
Drainage Design
Drainage Design
I am currently working on an urban roadway widening project, which is about 3 miles long.  I encountered a problem when designing drainage.  The site is flat and constructing series of underground culverts is not feasible. Therefore, I came up with two alternatives:
•    Raise the existing pavement and construct an earthen ditch along one side of the roadway
•    Construct earth berm
However, these two designs will require additional ROW.  Can anyone suggest a drainage system with less impact? Thanks for the help.
RE: Drainage Design
bico1010,
This is a widening of an EXISTING road ?  How is this roadway and right of way drained now ?  If there are existing culverts, why can't they be extended ? If there are no culverts, only ditches along the alignment, why can't they be relocated along, and parallel to, the widened section ?
Good luck
RE: Drainage Design
constructing a berm may not be a feasible approach, since this could cause ponding on adjacent property.
RE: Drainage Design
How much drainage is there across the road now, cfs and culverts?
RE: Drainage Design
There are no existing culverts, and the flow is about 1000cfs.
RE: Drainage Design
Unbelievable ! 1000 cfs drains along or across this road, or both.  Where does it go now ?  Does it just disappear into the earth ? Does it flow over the road uncontrolled ? Doesn't this create a problem for traffic?  If ther is no traffic why on earth does it need widening ?
Enlighten us, PLEASE.
RE: Drainage Design
hopefully the 1,000 cfs is not in one location but in several along the 3 miles.  Is this 100-year flow?
RE: Drainage Design
This 1,000 cfs is projected 1% or so flow I presume.  The grade of the three miles is flat? What will be damaged by ponding?  What is the traffic count?  Lots of potential solutions, depending on the particulars.
