Corrosion under carbon fiber composite
We are reinforcing a steel plate with a wet-applied carbon fiber composite. The bare steel is primed with epoxy primer. The carbon fabric (PAN) is wetted with an epoxy and, while the primer is still wet and uncured, the wet carbon is layed over the steel. Several layer are used, all wet when applied and pressed into place.
Now the composite is fully cured and we have cut the part in half to reveal a layer of steel and a layer of carbon composite. When we check the outside surface of the composite to have continuity with the bare steel, we have none. The epoxy is thick enough on the surface to isolate the carbon surface from the steel. When the carbon composite edge (that was exposed by cutting, the part in half) is checked for continuity, it is hit and miss. Some of the carbon is isolated from the steel and some is not. Also, some of the carbon is isolated from itself and some is not. We are trying to establish that the carbon may or may not contact the steel directly and , if it does, has no corrosive impact on the steel. Is this a true statement, "The area under a carbon composite repair will not corrode due the the absence of an electrolyte." Corrosion must hav a cathode, anode, and electrolyte. Has anyone researched this area?
PAN fibers would be more noble and cathodic while the steel will be the anode. If no moisture is present, what if anything, will act as the electrolyte after the epoxy has cured?
Thanks, awol
Thanks, awol
RE: Corrosion under carbon fiber composite
As a small piece or trivia, a large portion of the Ti being used on the 787 isn't for its superior structural abilities. Instead, it's simply because graphite likes to consume aluminum.
Thanks.
Tapas Laha
Miami
