Manufacturers of Flanged Fittings?
Does anyone know of any manufacturers that manufacture large diameter flanged fittings according to ASME B16.5? If not, what schedule and size of tee would be required to meet an ANSI Class 900 10 inch tee?
Is the best bet to get a scheduled butt weld end pipe tee and weld a welding neck class 900 flange to it? (Bore of the flange specified to be the same as the pipe schedule)
If so where should I look for fabrication/purchase?
Thanks for any help,
Nick
Nick
RE: Manufacturers of Flanged Fittings?
http://
There are probably other suppliers out there if you want to get more pricing.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
As to what schedule of pipe/fittings matches a flange class, that's a service-specific question. The butt-welding tees and other fittings have schedules which match the schedule of pipe you're using. The required schedule is determined based on material safe allowable stress for the service condition, corrosion allowance and lots of other factors. Depending on these factors, different schedules are needed to match a flange class. At 900# class, it's unlikely the schedule will be lighter than sch 40, but it may require XXS- without more information, nobody can tell you the correct answer.
Cockroach: Swagelok and Crane only seemed to carry smaller diameter fittings unless I am way off in my search. For TIW is that TIW Corp in Texas? Do you know if they have a website?
moltenmetal: That seems to be the same problem I am running into as far as finding an actual 'Flanged Fitting' manufactured in accordance with the tabulated values from B16.5. Usually you wouldn't connect a flange to all three connections of the tee, but for this particular application it needs to be removable in sections. The working pressure in the line will be approximately 1200-1500 psi using a fluid that is slightly acidic, but all other properties can be considered as water. The tee will either need to be stainless or carbon steel with an epoxy coating.
Contact Quality Electric Steel Castings of Houston.
www.qesc.com
They would be more than happy to build a pattern and cast your Tee.
Todd
www.oxilume.com
