focusing a construction laser beam
I have a construction grade Craftsman laser level.
The beam appears about 0.08 inch wide at the range I want to use it, and is quite dazzling.
Is there a device I can use to re-focus the beam for better resolution?
RE: focusing a construction laser beam
TTFN
TTFN
Good luck and I hope this helps.
Scott
In a hundred years, it isn't going to matter anyway.
