Unlisted material, 7075-T6 Aluminum, for fitting design
I had a question regarding the use of an unlisted material for a design of a fitting.  I am looking to use aluminum 7075-T6, which is not in the ASME code.  I understand that for a fitting, there is more freedom for which materials can be used.  I was looking for some input on if this materail would be possible to use for this fitting.  Any help would be appreciated.
Thanks.
