Structural Insulated Panel Roof Diaphragms
Does anyone out there know where I can get some guidance on diaphragm strength of Structural Insulated Panels (SIPs) used to clad a timber-framed roof?
I have heavy timber (likely 12x16 or bigger) tied-rafters 13' o.c. with a 8 on 12 pitched gable roof. Building is 40'x80'. I would like to span the SIPs between the rafters and have no purlins, or ridge beam, between the timber rafters. Essentially the SIPs would simple-span between the rafters and their only connection would be only to the top of the timber rafters and a continous timber around the roof perimeter, which supports the wall infill studs between the timber frames and serves as the diaphragm chord members.
Any help would be appreciated.
Thanks.
RE: Structural Insulated Panel Roof Diaphragms
htt
Thanks for the replies. I will look into the Va Tech and ICBO reports.
Thanks again
