plating rack construction techniques
Are all plating racks hand fabricated items with very low precision?
Does anyone make racks that are manufactured so that the locations of the clips is held to a tight tolerance?
What about just using a drawing or CAD model instead of working from a part?
RE: plating rack construction techniques
Unless you have special requirements, they should fit for any range of tolerances.
http://www.welding-advisers.com/
