Lineweight positioning
Someone has posed a question that has me stumped, they were shown it on a course but cant remember how to make the choice. Where is the selection that you can place the line weight postion so it is not on the centre line setting.
RE: Lineweight positioning
"Everybody is ignorant, only on different subjects." — Will Rogers
Thanks for the reply.
The person told me its similar to using Multiline where you can set the position for the offset line to be either centre/top/bottom alignment. With the lineweight button selected highlighted then the preview lines are shown above/below or centred. I think the idea is so that close adjacent lines can still be shown? It maybe in the print options somewhere. Will check it out and post if I find it.
http://www.cadtutor.net/michael/mc0308.html
