Cut Tread vs Rolled Treads
I have read the weakest area of any mechanical fastener is the minor diameter of the threads. Since the thread dimensions of a cut thread and rolled thread fastener are identical, I would like to know if there is difference in strength between the two.
I have seen a lot or cut threads fail in structures and some manufactures call out both type of fasteners in the same part. An example is having two cut threads fasteners and two with rolled threads fasteners in a elevator fitting in accordance with the IPM.
Is there a reason to be concerned?
Stache
Stache
RE: Cut Tread vs Rolled Treads
Cory
