Lead Power factor
Lead Power factor
Is there anything wrong to have a lead power factor?
We just injecting reative power to the utility right?
I have specified a capacitor banks that will fix the power factor to above .95;however if the load drops the power factor migh lead.
I am aware of step cap. banks but I just want to know what would happen by having leading pf?
RE: Lead Power factor
Keith Cress
Gunnar Englund
www.gke.org
In all of the utilities I have ever seen, the main circuits tended to run at 80-95% p.f. lagging (depending on load characteristics and line capacitor policies). So long as your facility is not so large that your leading pf drives the entire utility circuit into leading pf, the utility actually 'wins' (especially if they get to charge you extra for reducing their reactive power flow and supporting their circuit voltage!).
I am mainly concern about the technical problems that this may cause.
As I understood the leading pf can increase the voltage level at the PCC which makes sense.
Instability is a problem that the generation centre would need to concern about and us as a customer have nothing to do with it.
I understand that when we are injecting Reactive power to the circuit that can be used somewhere else in the system , but how this is metered I don know.
Does anybody have a literature on common hydro metering devices?
Theoretically this would allow you to "subtract" KVARhrs from your meter during periods of light loading, such as at night when the equipment was shut down but the capacitors were still connected.
In reality, many Utilities installed a ratchet in the meter so that it would not run backwards. When the power factor was lagging, the meter recorded KVARhrs, when the power factor was leading, the meter simply stopped.
respectfully
Actally the chances of a generating facility even being aware of it is virtually nil, because the great majority industrial loads are lagging. David's point is valid if you have private generation or your facility is a large part of the load on a embedded generator on the local utility distribution system. In this case the generator may well run into stability problems if it is required to run at a leading power factor.
The people who are more likely to be those who share your utility PCC because their voltage will possibly be affected. If you have your own dedicated transformer or a private HV intake, then any problem is essentially yours and the utility will privately thank you for reducing their VAr loading a little.
I don't suffer from insanity. I enjoy it...
Keith Cress
At my plant the utility charges for any lagging PF and none for leading PF, therefore, we are always leading.
I reply because I recently experienced this exact problem with one of my clients. There was no problem running on utility power but the backup generator had problems until we removed the capacitor which was causing leading power factor.
Keith Cress
No apology wanted - I'm just poking fun. I was trying to say that a central utility generating plant wouldn't even notice if one small load went from lagging to leading, but an embedded generator belonging to the utility and local to the site might see the change, and an islanded generator belonging to the siteb would be likely to see an adverse effect if the pf went significantly leading.
We are saying the same thing for sure.
The FCC and power co have decited that
cap loads are bad.
In cap loads current peak leads voltage peak.
In inductive loads current peak lags voltage peak.
Forty years ago loads were resistive (0 pf) or inductive
(-pf, or laging.
With computers, audio, and so forth, loads have become
leading (+pf).
If your substation is 1000kw and you are using 100kw,
you are 10% of the load, at 10% pf leading or laging
only your meter knows.
Forty years ago power co had sync motors, cap banks,
to correct for lags.
In a nutshell, it costs more in copper/iron to allow
non "0" pf + or -.
There can also be overvoltage problems if there is too much capacitance at the end of a lightly loaded line.
I dont mean to counteract your statement but
"From the standpoint of heating and losses, the lead/lag of the power factor does not matter"
Just would like to have more insight. Leading power factor means transfer of reactive power back to utility and lagging means from the utility back to load. In both issues, there will be heating as power is flowing. So Could u advise what you mean here. Again, I don't mean you are wrong.
I have recently commissioned a 4.3 MVAR\Phase Ungrounded Wye PF Bank at a Clients Shredding Operation (4000 HP Wire Wound Rotor w\Liquid Rheostat). It is Tuned to the 9.8th Harmonic.
At Idle the Bank leads a bit, and it is .94-.97 under load.
The serving Utility does not care about the Leading VAR's, and in this particular application, they will rarely be at Idle.
I would have to say, the Utility, and Application will determine if you can get away with the leading KVAR's.
Mike
{((KVAR per Phase)/(KVln))/Ibase} * X1 = %VR
The utility won't have to have additional capacity to carry the leading VARs because this will be during periods of light loading, the capacitors will result in freed capacity during peak load periods.
From the utility perspective, I would rather have you be at 95% lagging on-peak (when VAR support is most needed) and 95% leading off-peak than to have you at, say, 90% lagging on-peak and unity off-peak. {But our accounting department would still insist on charging you the leading power factor penalty}
