Transistor Selection, Replacing PN2222A
I have a design that is currently using a PN2222A Transistor, it is on the output side of a LM723 Voltage regulator, to increase the current capability of my voltage regulator. The circuit is designed to output 12VDC, the collector is connected to a 24VDC source.
The problem that I am having is that I have noticed that this transitor will fail from time to time. It seems to be rather fragile. Can anyone recommend a replacement for this transistor that might be a little more robust.
Thanks.
Thanks.
RE: Transistor Selection, Replacing PN2222A
1)What sort of current are you trying to get the PN2222 to pass?
2) What sort of current limiting have you used?
3) If you have a large output capacitor and or conditions of light load current this could stay charged up at 12V when the input power goes off. Have you got a reverse blocking diode to protect the regulator and the PN2222 transistor?
Keith Cress
I have not noticed excessive heat from the transitor.
The 1k pot is used to "tweak" the output voltage to 12VDC.
R3 represents the 360 ohm load that is normally on the circuit. There is also a 1W load that is not shown in the simulator.
Thanks for your help.
The PN2222 can dissipate a maximum of 625mW according to Fairchild's datasheet. You need a transistor capable of dissipating more power, and it might need a small heatsink, depending on the package. The Zetex ZTX453 is one of numerous possibilities - TO92 package, no heatsink required, voltage / current / power ratings are all ok.
I don't suffer from insanity. I enjoy it...
Keith Cress
http://w
Note: eng-tips will not link to this correctly because of the "?". So you will need to cut and paste.
Otherwise it will still toast. 1 Watt on a package that size in free air translates to about 300F, that's just the physics of heat dissipation.
Keith Cress
what about reworking it to use something
with a TO220 case like a TIP3055?
If present, such oscillation can cause lots of power to be dissipated in the transistor.
