extruded PA Glass Fiber reinforced
Hello, I am not an engineer so I may be posing a silly question: can extruded pa 6 or 66 glass reiforced extruded tubes be formed, bended just like metal tubes? what process would be needed?
The idea would be to buy extruded tubes cut and bend them afterwards.
RE: extruded PA Glass Fiber reinforced
You would need to heat it to its softening temp, which is so close to the melting temp that it could not be maintained with enough accuracy to maintain a suitable operating window.
You would need to pack the tube to prevent collapse.
