supplier for high temperature asphaltic coating
could any one help me to find supplier for high temperature (260 degree C) asphalt coating.
our application is to revamp Primary Reformer.
appricate any help/ suggestion
RE: supplier for high temperature asphaltic coating
if no supplier is available in middle east please advice supplier in any country
thank you for your advance help
Isn't a Primary Reformer part of a nitrogenous fertiliser production process? I thought they run hotter than 260 degrees (over 800 degrees)?
www.asphaltkingdom.com
http://www.welding-advisers.com/
http:/
On other possibility is the coatings used on the beds and frames of pickups. I recently saw pickup that had burned and part of the bed coating still looked good.
