Instrumentation codes and standard
Dear respectable sir,
i hesitate before submit this thread because i don't know if it's the suitable to this forums or no.
any way i'm new instrument engineer iheard about ISA and API and IEC..... and i want to make private instrument standard for our refinery.
according to what i shall choose the item or it belong to certain country ? or according to what consideration i shall chose the standard to make our private one
also what the difference between standard and code?
thanks
thanks
RE: Instrumentation codes and standard
http:/www.jraef.com
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
If I understand your question correctly supeing, code is generally the requirements of the authority having jurisdiction (AHJ) at your location.
Standards are rules that are set up so everyone at a particular place can understand how your particular instruments are utilized and installed.
The word 'standard' of course, can be applied to mean code also because the 'code' is a standard of the AHJ.
A company standard from scratch would be a huge undertaking. You should probably look for, or try to adapt, your company's standard from an existing one or ones.
You could check with the ISA and API and IEC organizations and see if they have 'standards' you can acquire.
Keith Cress
Anyway, you are on the right website for this forum.
"No man really becomes a fool until he stops asking questions." -- Charles Steinmetz
