What are the standards for control joints in concrete???
I was wondering what the industry standards are for vertical and horizontal concrete? We believe we may be way overdoing our control joints at 8' for 4" flat concrete and every 12' for 6" concrete. Also, we have lost a job because of our reccommended thickness for a basement foundation wall. We recommended a 12" thick 9' tall wall for a 66' span. Did we overcompensate with concrete thickness? What would you have reccomended?
Sincerely,
Brad Kriegel
General Partner
Sincerely,
Brad Kriegel
General Partner
RE: What are the standards for control joints in concrete???
Designing Floor Slabs on Grade
Also, make your joint pattern as nearly square as practicable and with no more than a 1.2 to 1 ratio of length to width.
Publications from the "Foundation Performance Association"
http
US Army Corps of Engineers, "Concrete Floor Slabs Subjected to Heavy Loads"
htt
National Research Council, "Criteria for Selection and Design of Residential Slabs-on-Ground"
http://newton.nap.edu/catalog/9804.html#toc
The way it is presented, this one takes a lot of patience (download one page at a time)
www.SlideRuleEra.net
Dik
Dik
