SS pipe thickness
SS pipe thickness
SS pipe thickness
We have some SS 316 pipelines from 2 to 12" nominal size. The pressure is 0-5 psig and temperature is -45 degree F.
While assessing the NDT reports for these pipelines it came to light that all these lines are sch.5 and sch.10. ( 1 to 3 mm thick).
Even though the thickness is ok for pressure temp rating is is good for mechanical strength point of view. IS there some minimum thickness guidelines for pipe line design
RE: SS pipe thickness
Which standard you are using for your design?
Minimum diameter to thickness ratios are usually around 100 - 120 or so.  There is often a minimum D/t ratio required by the specific code you are working to, look there.
From tabulated data, nominal 12-in pipe wall thicknesses for Sch 5 would be 3.96 mm, and for Sch 10, 4.57 mm.
Much thinner wall spiral wound stainless steel is often used. What you need to use is basic beam theory to establish the stresses and deflection. Up to 6" could be dairy tube rather than Sch 5 or 10S.
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
