Task Bar (Application status & Process) throgh VB6
Hi All,
Is there a way to find out if a particular application is runnung or hung? If so can we terminate that application through VB code.
When we hit Ctrl+Alt+Del we would see the task bar, where if on application tab the application status is not responding we can delete. We also can terminate a particulat process from the process window. Can this be possible programatically using VB?
esr
esr
