Settling Velocity and Particle Size distribution- Coal Combustion.
I am in the process of designing a temporary wastewater sedimentation (settling tank) for a coal fired power plant. I am trying to get more information of particle size and settling velocity for coal combustion by-products. The data available based on literature review almost always suggests that it is dependant on the type of coal and the efficiency of the combustion process. Also, I was able to glean some data suggesting that particle size is less than 10 µ m with a varying range from 0 to 15 µm. Can anyone direct me on information regarding settling velocity information and their variation for various seasons (summer and winter) for Coal Combustion by-products, particularly coal ash and fly ash? Any particular column tests for the same processes will also be of help to me.
Thanks in advance.
Thanks in advance.
RE: Settling Velocity and Particle Size distribution- Coal Combustion.
The particle size and componenets were ever changing. Iron salts proved to be the most problemmatic as they afect the apparent viscosity.
The slurry was pumped away at a solids density of 72% 11km to a mine site.
Settling was not an issue as the particle size s generally small. Bottom ash was handled separately.
Search the internet for papers on this project. BHRA may have papers on slurry pipelining of fly ash.
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
Thanks.
Mani
As to a pilot test, you can probably send a sample to someone like Westech and have them predict the settling performance on a bench test.
If you are interested in something temporary, why don't you just rents some tanks from Baker Tanks. Those tanks are frequently rented for temporary use.
Thanks again.
Use of rental containers such as those supplied by Baker Tank and others is common on construction sites for storm runoff, etc. Flow goes in one end of the tank and overflows the other end. Some users cascade from tank to tank to increase the efficiency of treatment. The tanks are basically semi tractor trailers and were originally used in the oil fields to separate drilling muds and other uses.
www.SlideRuleEra.net
What is the purpose of relining the basin? And the type of liner.
Have you thought about just replacing a portion of the basin at a time. You can sheet pile half of the basin.
At Stanmore power station in Queensland dense fly ash spews from a vertical pipe and forms a mound. The water drains and is collected and returned to the process. When the mound gets to a certian height they fix another length of pipe to it and keep pumping.
Consider dense phase pumping over lean phase. Saves power and water.
Your project may involve repairs to a much smaller pond to take care of "blowdown" (the electric utility term for discharge water), but it does not sound like it.
Also, what is the total nominal size (in electrical megawatts) of all units (there may be more than one) that your project will have to process? This will give a rough idea of how much ash will be coming in. For just about any commercial size coal fired generating station "dealing" with the ash is as much a material handling challenge as it is a waste treatment problem.
bimr - The 6 MGD flow rate makes sense if this is the primary ash system. The same sluice water is continuously recirculated to transport ash. As you have noted, the discharge flow rate to the environment is much lower.
Also, both fly ash and bottom ash contain heavy metals pollutants that tend to leach into groundwater. A pond liner is to keep this from happening.
Here is some general information on coal fired ash handling systems:
http:
http:
Do you have an ash dewatering bins? If not, you probably need one.
http://www.unitedconveyor.com/partsdata.html
Seems like you need more work to design an economical ash handling system rather than a sedimentation tank.
Slideruleera:
I think it is still a temporary wastewater influent treatment problem because the exisitng wastewater lagoon/basin (which is 13 acres in size) will be active after the liner is replaced and will be able to handle the normal and peak flows and meet discharge requirements.
There is a separate ash basin to handle all the ash that is settled in the existing wastewater basin.
The temporary wastewater system ( I am thinking more like a temporary aboveground sedimentation tank/solids contact clarifier that can be installed to take in the influent flows and handle all effluent discharge requirements). The important discharge requirements include suspended solids, oils and heavy metals).
I do not have exact information on the amount of ash generated. I am still looking at the logs and initially it looks like the particle size is 10 to 100 um and very fine with a suspended solids concentration of 2-10% in the influent...
Any modifiications or more efficient methodology will be of great help ..
Thanks....
...but encourage you to find out how much ash is produced - I think you will be surprised. Got to "put" it somewhere. Bimr bring up a good point about checking with United Conveyor, they are a leader on this type problem. A competitor is Allen-Sherman-Hoff (ASH)
htt
If you discuss your project with representative from either, or both of these companies - they will probably "jump thru hoops" to give you suggestions (on how to solve it with their products). Which may be what is needed.
How are you coming along with this? I have a similar project for a permanent install. I'm looking for clarifier/thickener installations here in the U.S. for proof of principle. My client will want to visit an installation if they go forward with the design. You do have to take into account where you're going to pump the ash that you settle out of your flow. My initial flow is 8100 gpm (12 mgd) and @2% solids. You can determine your solids density if you know the higher heating value and ash content of the coal burned, the heat rate of the plant, as well as the load they are running the plant. For example, I have a 1350 MW plant with a heat rate of 10,000 btu/kwh; This gives me a heat input of 13500 MBH/hr at full capacity. My coal is assumed to have a HHV of 11,000 btu/lb. From this I calculate the tons of coal per hour that I'm burning. Now, the client told me that the coal has an ash content of 7.13% and that 90% of the ash is fly ash. My fly ash production rate is, therefore, 39 tons per hour at full load, or about 61 gpm (dry volume).
If you're dealing with hydroveyors like I am, then the water flow rate will remain constant (8000 gpm for my example), but the ash content will vary based on load. Toyo pumps has a picture of a treatment facility in New Mexico that uses clarifiers to thicken ash. I'm trying to track it down so I can track down the thickener manufacturer. My design to get 2% up to about 5-7% uses two 100 ft. diameter clarifiers. To go from 20% to 50% solids (another option we're looking at) it takes the same size clarifiers. The number I've been getting is something like 0.3 to 0.5 gallons per square foot of clarifier area for sizing. But as you've probably determined from your internet searches is that it's all a guess until you get the rheology report for your particular plant. The amount of carbon left in the ash as well as the condition of the ash (are the spheres broken and jagged) as well as the calcium content all have an effect on the performance of the fly ash. If you're burning PRB, you can run into cementitious problems. You might contact Dorr-Oliver Eimco for more assistance. They have an example of a facility they installed overseas (Gale Common, British Energy). You'll probably end up with a polymer additive so you get agglomeration and quick settling, which would not be that much more expensive or complicated for a temporary installation. I have to steer clear of complexity on my job. But you are talking a lot of expensive equipment to handle that flow rate to create a sludge that you can handle. The estimate I got for my two 100 ft. diameter clarifiers was between 1.5 to 1.7 million...just for the clarifiers; no pumps, nothing else. Just parts and installation of the clarifiers (metal aboveground tanks). I imagine you'll have to solidify to at least 60% so it can be stacked somewhere for drying prior to loading for landfilling? I'm just guessing. I hope you're still monitoring this thread b/c I think we may be able to help each other out.
I think you would be better off using dense phase pneumatic conveying to handle the fly ash into a silo. The fly ash from your precipitators or bag house canbe conveyed by airslides to the pots. Pneumatic conveyors can transport the ash 1km if necessary to the silo. From there you can blend it with water in an agitated tank to make a paste for dense phase pipelining (72% solids) or lean phase slurry (23% solids).
It seems a nonsense to mix with so much water and then try and separate the ash in a gravity thickener. The ash is so fine that you will use an enormous amount of coagulant & flocculant to get it to settle. On top of that the pH, temperature, chemical composition, solids distrubution etc will vary so much that you will never get your chemical dosing right.
The above dense phase process has been used in Australia on a 4 x 660MW power station and a 4 x 500 MW station.
Contact Kockums Bulk Systems for the pneumatic conveying.
Thanks for your info. You are sooooo correct, and you gave me a good chuckle this morning, kind of a "no s$&*" chuckle (no offense....you really are correct, and I needed the laugh this morning). I guess I should have shared that my client's plant is 54 years old and that I'm working with a system that United Conveyor Corporation designed for my client over 50 years ago. It does take up little space with the components used, and is low maintenance, but boy oh boy is there a LOT of water used. That doesn't even include the water used for the bottom ash!!! Considring the age of the plant, and the fact that bailing wire and duct tape is used to keep it operating, there is also no hope of retrofitting a pneumatic system in this plant. Just gotta work with what's there.
I appreciate you taking the time to respond!! Cheers!!
Sorry for the late reply. Thanks for all your input. I am still in the process of characterizing the influent. I did contact USFilters and Enprotec on temporary clarifiers and the maximum capacity they have is 1000 gpm (1.44 MGD) which in my case will need 4-6 tanks. At this point, I am really trying to nail down the actual flows for the actual months of construction which might occur in the Fall and cold weather might set in and affect clarifier performance. Please keep us posted on this thread on your progress and contractors/manufacturers who specialize in equipment required for what you are trying to do.
Thanks.
