HV XLPLE Cable sheath testing
Any one please discuss regarding HV XLPE cable sheath testing. Where DC Hipot test kit terminals to be connected for cable sheath testing?
Advanced thanks.
Advanced thanks.
RE: HV XLPLE Cable sheath testing
Not as easy as it sounds sometimes. The best thing to do is to obtain drawings from the MFG on how the ends were sealed for shipment, how the cable will be installed (link boxes connected, etc). This will explain how the cables are sealed and therefore how you will test on the reel. Mfg. typically remove some outer semi conducting layer for reel testing so that part is simple. You want to insure testing is performed per the MFG instructions.
After pulling tests can be identical to reel tests if sealed ends are left intact.
Final tests after all installation require require some thought and inspection of cable run to insure no inadvertent grounding of sheath through clamps etc.
