Exchanger noise and vibration
Guys,
There is an air cooled exchanger in our plant (Hudson Hei) for cooling down hot oil service. Recently we has a problem of theis unit trip due to high vibration. We are used to get a vibration company does equipment condition monitoring for us and he advise to check the condition of drive belts and pulleys and if needs be, change the belt. Apart from that, anybody can say if he has experienced similar problem?
The cooler is currently operating with noise.
RE: Exchanger noise and vibration
You can also get a spray on 'belt dressing' (google for details) which you can quickly apply to the running items to see if the noise goes away
