Catia v5 sketcher patterns
Is there a better way to create patterns in sketcher? The only way I know how is insert-operation-transformation-rotate(translate). When doing this a pattern object isn't created, so parameters, such as number of instances, can not be easily changed later. Also the definition method is very restrictive. For example, in a radial pattern, the only way to define it is by number of instances, and angle between them. What about number of instances and angle to fill, or angle between and angle to fill? Thanks in advance!
RE: Catia v5 sketcher patterns
If you have something specific you want to drive the sketch with, then drive the pattern with a formula (knowledge based design).
CATIA does not have pattern feature in the sketcher.. unfortunately.
However, you can pattern your sketch using the "Pattern" option/icon available in GSD workbench.
Can you elaborate?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Derek
Can you share with us how to pattern a sketch in Part Design WB.
This allows for extended flexibility in assembly design. (Re-use pattern in Assembly design)
Derek
I used to have a lot of trouble with FEA analyses done on a part that had 4 variable fillets, because of the way the fillets met the vertices. (due to the closing points of the sketch/pad) I solved it by creating a partial sketch, and patterning it. I also created the variable fillet 1 time, and patterned it from extracted faces. (Catia doesn't know how to solve the vector direction of variable fillets) My results became 100% consistent, and it solved a number of other issues.
Need any more explanation? I'm a big proponent of minimalistic sketches, and patterned features. I agree with Derek 100% on this one, which is why I also asked SooDesuNe to elaborate on the part a bit more.
Derek
We're talking about a sketch creation *methodology*, here. Not some new form of patterning..
Is that clear enough?
