Importing (x,y,z) coordinate files
Does anyone know the specific command for importing a (x,y,z) coordinate file into Unigraphics?
RE: Importing (x,y,z) coordinate files
Method 1: Use can use GRIP command to write a program
          to import this X,Y,Z coordinate files provided
          that you have the GRIP execute module license.
Method 2: If you don't have the GRIP license. You may
          write a program in any language(ex: Visual Basic)
          to read all the coordinate from that file and
          convert them into IGES or DXF format and then
          import into UG.
Method 3: In fact, If you already sign a maintenance     contract with UG Solutions, then you will be able
to get the availble sample of GRIP program source file through UGWEB by www.Ugsolutions.com
SK Neoh,
THONG FOOK (Tooling Department)
IPOH,Malaysia
email: skneoh@tfp.com.my
u can import the x y z file directly through curve or surface creation. no grip is necessary
