17-7 PH/C vs. 316 Stainless Steel
I need to select a wave washer that will hold up under salt and chlorinated water enviroment. The 316 costs approximately 12x times as much as stocked 17-7 PH/C. Is 316 worth the additional cost?
RE: 17-7 PH/C vs. 316 Stainless Steel
On the other hand it maybe that duplex stainless would hold better than 316. A detailed comparative study should probably be conducted.
http://www.welding-advisers.com/
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
