AutoLISP: Retrieving atoms from lists
I have written an autolisp program where i generate a list of points that i would like to connect with the SPLINE command. The problem I am having is that I have been only able to get the spline command to recognize the first element of the list automatically. Following is the basic code:
code:
(repeat 5
(setq pt2 (getpoint ("\n enter point")))
(setq l1 (append l1 (list pt2)))
(command "spline" (car l1)
As you can see above, this routine will get me the first point in the list l1, however, if I try to loop to get futher points in the list, I am not able to get further in. Does anyone know how to go about this process? Thanks!
Tom
code:
(repeat 5
Tom
RE: AutoLISP: Retrieving atoms from lists
(setq no 0)
(repeat (length pnts)
(setq no (1+ no))
(command (nth no pnts))
As you can see, you only call the spline command once, then successively use (command point) until you are at the end of the spline. One note however, the third to the last point must be an empty carriage return for example:
(setq pnts (list
'(1072.25 844.75 0.0) ;start point
'(901.875 872.25 0.0) ;next point
'(984.313 1152.19 0.0);next point
'(1182.13 1327.81 0.0);next point
'(1610.75 1437.63 0.0);etc
'(2281.13 1509.0 0.0) ;etc
'(2676.75 1338.81 0.0);etc
'(3000.94 1157.69 0.0);etc
'(3105.31 1503.5 0.0) ;etc
'"" ;close point selection
'(3814.19 1607.81 0.0);start tangent
'(4072.44 949.063 0.0);end tangent
Hope this helps....
(command "spline")
(while (setq pt (getpoint Enter point: "))
(command pt)
(command "" "") ;this is to exit out of spline command
Another way is to build a pointlist:
(setq ptlist nil)
(setq ptlist (cons pt ptlist))
(setq ptlist (reverse ptlist))
(command "spline")
(foreach x ptlist (command x))
(command "" "")
Hope this helps,
Carl
mapcar lambda
but I could never make good use of these. Maybe someone will post here.
