Change direction of Weldment Structural Member
Does anyone know how to change the orientation of a weldment structural member? I know how to rotate it, but for an angle, that only gives you half of the possible orientations. One thing I have discovered, is that it depends on the "direction" that you draw the line. However, often this is not convenient to change your sketch.
See the attached screen shot for additional clarity:
http: //www.mool oad.com/ne w/file.php ?file=file s/300606/1 151676176/ angles.JPG
Thank you,
http:
Thank you,
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: Change direction of Weldment Structural Member
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
SA
