Edge Display for Cosmetic Threads
I'm using Pro/E 2001
I have an external cosmetic thread on a ring that I want to show in section. The thread only extends part way down the outside surface of the ring.
When I create the section view the bottom edge of the thread, the edge part way down the ring, is always on view.
I have switched off hidden lines and tangent lines, I have tried to delete the edge but I'm assuming that, because it is a surface, that the line isn't controlled by edge display.
Can anyone help on this?
RE: Edge Display for Cosmetic Threads
hlr_for_threads
