Inconel X-750 spinella thickness measurement
The microscope/image program I use will allow me to measure increments as low as 100 nanometere. The minimum thickness of the spinella is approx. 500 nanometers. How do I "treat" the sample mount to develope a readable interface between spinella and base metal? geboy
RE: Inconel X-750 spinella thickness measurement
As I recall you use an electrolytic extraction, but you stop before things actually fall out of the structure. I'll look for hte solution that we used.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
