Slow regeneration or loading
We had decided to migrate from Pro Engineer to Solid works and started implementing the move. We just started using Solid Works and we noticed that complicated solid models with large numbers of features (a hollow cylinder with 240 holes w/c-bores) take an unusually long time to load or regenerate compared to ProE. This is very disturbing and we are wondering if we've made a mistake by changing from ProE. Could there be some solution for this issue?
RE: Slow regeneration or loading
How long is "an unusually long time".
A quick test on my home computer using a hollow tube with a c'bored hole patterned radially and then linearly (240 holes total) resulted in an opening time of about 2 seconds and a regen of features (CTRL-Q) of about 6 seconds.
My machine is a P4, 2.4GHz, 1MB Ram, ATI radeon card (non-certified), SW2006, SP4.1.
What are your system specs?
Are you working locally or over a network?
Are you using a PDM system?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Selecting the Geometry Pattern option when doing a pattern feature can dramatically reduce regen times. When unselected, my model took about 24 seconds to regen.
cheers
I'm curious ... Why did you decide to upgrade smile to SW and which version of Pro/E are you migrating from?
cheers
Ahhh, hi Jeff ... I was begining to think I was the only one who could see this thread ... or maybe just being this ignored. cry
cheers
We have P4 2 GHz machines with 1 GB memory. Our graphics cards are Nvidia Quadro4 980 XGL withe the latest drivers.
We decided to try Solidworks for cost savings. ProE is rather expensive, the maintenance cost alone is over 50% of the cost of the Solidworks seat including training and maintenance.
We were very motivated to make this work. We still would like to find a way to make this software work for us so we'll try your suggestions and input. So far we think that the graphics engine of ProE is just much faster than Solidworks.
What we did was to model the same part we had in ProE with Solidworks, then we created a drawing (this was done by the reseller's expert). After we loaded Solidworks in our machines we were able to compare directly the performance of both programs with similar files. We only did this because we noticed long waits while the drawing and solid geometry loaded in our screens. Solidworks takes 5 to 10 times longer than ProE to load these files. Then we modified the solid models in similar ways and measured the time to regenerate the parts. In this case it took about 15 times longer to regenerate the parts with Solidworks than with ProE.
The part in question is basically a tube, 18" OD x about .75 wall. It has some holes patterned on each side of the tube, some shallow channels about 1.00 wide equally spaced. In each of these channels there are 40 holes eually spaced around the outside wall with counterbores. The original part had 6 channels with the holes and the modified part was made longer so it could have 10 channels with the 40 holes per channel.
After the modification it took ProE about 10 seconds to regen, and Solidworks about 1.5 minutes... Perhaps there are some tricks or settings that we don't know to accelerate the Solidworks performance. We'd sure like to find a way to make it work for us.
Try Tools/Options/Performance and make sure that "Verification on Rebuild" is unchecked.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
"Selecting the Geometry Pattern option when doing a pattern feature can dramatically reduce regen times. When unselected, my model took about 24 seconds to regen."
OK, we tried this but we did not get any noticeable improvememt. We are not working over a network or using PDM.  Another issue of speed involves the hourglass that appears each time we spin, zoom or pan the part while in hidden line visible or hidden lines removed state. The hourglass appears for several seconds each time we manipulate the geometry while it changes from wireframe to whatever state we are working with, we do not experience this phenomenom with ProE...
"Try Tools/Options/Performance and make sure that "Verification on Rebuild" is unchecked."
Thanks Jason, I just checked that and it's as you suggest....
You mention you are using the latest drivers for your card. The latest from the nVidia aren't necessarily the best for SW. Assuming you are running SW06, the SW certified driver for your card is 6.14.10.7756, is that the one you are using? It probably wouldn't make a difference to the regen speed, but you never know.
As I mentioned before, using the Geometry Pattern option often helps.
If you can post the part for others here to download, (see FAQ559-1177) we could give you comparitive load & regen times on different systems. Also we may be able to offer alternate ways of creating the features to better suit SW.
cheers
Can't remeber the exact driver, but it was the one specified as certified for SW... And no, it did not make any difference from the 3 year old driver I was using before. Thanks for the tip about http://www.eng-tips.com/faqs.cfm?fid=1177
I'll look at it first thiong Monday and post the files for download.
I use both proE and SW and I don't notice any difference in terms of better performance between the two softwares; proE is more stable and SW has better graphics quality, and better view rotations using the middle mouse button.  By optimizing softwares and techniques you can greatly improve the performance of each softwares.
Ooops ... I completely missed one of your posts;
Quote (Silver92b 17:22):
It sounds like an unwanted process is running when you are using SW. Have the task manager running before starting SW & watch to see what processes start along with it.
Do you have any SW "add-ins" selected to be started when SW is opened? To save resources, it usually pays to start the add-ins only when needed.
Do you get the hourglass problem when using the shaded modes?
cheers
Thanks for the input SG20, unfortunately our experience (there are tow of us engineers) is 180 degrees from yours except for stability (I don't know how stable SW is). The graphic qualities of speed and aesthetics of ProE are quite superior to SW in our present configurations. As I originally stated, the regen times are 5~10 faster with ProE and actually the rotation, zooming and panning are also better with ProE.
We are extremely motivated to make SW work. However, we cannot ignore what we are experiencing. We've spokeb with our reseller about this. He suggested the driver upgrades. We've gotten some good suggestions from this forum about software configuration. Unfortunately these things have not helped. We are hoping that our reseller can come up with some good solutions. Otherwise we are in the uncomfortable position of telling our boss that we made a big mistake...
CorBlimeyLimey, Thanks for your input. we'll check ito the possibility of some process running. We do get the hourglass with the shaded modes but only at the very start while loading the part or after making a change to the geometry.
Silver ... Are you running Pro/E & SW on the same machine?
Do you switch the nVidia card "application settings" to match the CAD program being run?
cheers
Ok...I tried modeling something similar...round 18" diameter tube with a 3/4" wall thickness. I put in a 1/4" bolt hole with a c'bore. I then linear patterned it down 10x....then circular patterned it 30x for a total of 300 holes.
My computer specs:
P4 2.4ghz
1gb ram
nvidia geforce 6800gt video
WinXp sp2
Solidworks 2007 PR1
With the "Geometry Pattern" option checked (default)...it took 26.86 seconds to rebuild. With the geometry pattern option unchecked, it took 2.59 seconds. Quite a difference.
"Geometry Pattern on"
"Geometry Pattern off"
Jason
Quote (CorBlimeyLimey):
I did have the settings for SW in the video card. Yes, we are running both programs in the same machines. Tha's how we can A-B compare the programs....
Quote (Gildashard):
My computer specs:
P4 2.4ghz
1gb ram
WinXp sp2
Solidworks 2007 PR1
Jason, that model is very similar to what we made, we do have more features, but it's similar enough to compare. Your results are astonishing. As soon as I get back to work Monday, I'll try those settings. BTW, I thought we were supposed to run with the "Geometry Pattern" option checked for faster performance !?!?
BTW guys, thanks for your help. It's much appreciated.
Gildashard ... are you sure you have that right? Have they reversed the default (and option) in SW07? The default Geometry Pattern option on my machine SW06-SP4.1) is unchecked.
I just made a model using the same sizes & patterns as you and get the opposite results. Speed is much better when the GP is checked (7 secs) ... when unchecked it was 28 secs.
cheers
You guys are right....I got it totally backwards....guess its the weekend and my brain is screwed on backwards.
Jason
Perhaps you should have a couple of "Screwdrivers" to correct that disfunction lol
cheers
An "Edit Post" button would be better. banghead
Jason
Gildashard (Mechanical)
You have to put in a forum enhancement request to David for that one.
B.E.
OK, I tried the various settings on each of the patterned features. The results are varied but of course, they are much faster with the "Geometry Pattern" checked. With the unchecked option the regen times were over 100 seconds. With it checked they were about 11 seconds. However, that does not tell the whole story. The actual time that the hourglass is visible and the cursor is not available was 23 seconds when the Feature Statistics window showed 11 seconds.... Also, when I closed the document, it took a long time. I did not time it but it seemed like a minute or more before the solid model closed and the drawing file, which was open already, loaded on the screen  and I got my cursor again... Either we have some serious problems or unrealistic expectations from SW. BTW, the "official" software packages were delivered this morning.
What were you using before the "official" software packages arrived?
When you installed SW, did you disable whatever anti-virus program you use?
cheers
Quote (CorBlimeyBlimey):
We were using an "unofficial" copy of the latest software installed by the reseller until the "official" stuff was received... We wanted to get started ASAP and he was helpful with that. I'm glad we were able to play with it for the 1.5 extra days we had it. Otherwise we would not have found these issues.
The software was installed by the reseller himself. And yes, he disabled the antivirus software before installing it. Previously, he had given us "evaluation" copies of SW, but they were of an earlier version, so we did not work with them very much at all. Particularly since they were not very similar as far as the interface and funtionality as the latest version (which is what we have already).
Anyway, he was very careful to unistall all previous versions of SW and any other associated software such as Edrawings, etc.
I'm 99.9% sure that there is absolutely nothing wrong with the installation or configuration of SW in our machines. Of course, we were 99.9% sure about the performance level of SW vs ProE before we did our A-B comparisons....
Yeah...the features statistics only count the actual rebuild time of features. I think there is a graphics refresh going on there at the end that makes it take longer. Your card (Nvidia Quadro4 980 XGL) is fairly old and may be the reason for the delay. I would certainly look into upgrading that...especially if you are running the latest version of Solidworks. That card was probably current around the time of Swx 2004.
What version of Pro/E was you using?
Jason
Quote (Gildashard):
The card might not be so new, but it does work pretty well with the ProE Wildfire 3.0 (that's the latest release AFAIK)
So (just to confrm) you are running SW06-SP4.1 and Pro/E WF3? Aren't they about the same price now ... or is PTC still ripping the consumer for every add-on module & the subscription fees?
Before you make a final decision on whether SW is a mistake for you, please post the file for us to download, investigate & report back.
From what I've read in these & other forums, I don't believe SW is that much (if any) slower than WF. Patterns, however, are definitely not one of SWs strongest points. It also appears to be more sensitive to video cards & drivers.
cheers
I beg to differ CBL....Patterns were tested a few years ago and Solidworks regened large patterns faster than Pro/E, Solidedge, Inventor, and UG. Cant' remember where the post was or what forum but I remember it. Of course....that doesn't mean one of the other systems wasn't properly optimized....much like what we're going through now.
Jason
I modeled up the same part that Gildashard showed on my home machine.
SW06 SP4.1, core SW with only my spaceball add-in running.
Window XP SP2
AMD Opteron 144 1.81 Ghz
2 Gigs of RAM
Nvidia GeForce 6150 (onboard video)
Nvidia ForceWare 81.98
ASUS A8N-VM CSM Mainboard
With Geometry Pattern On, Feature Statisics shows 1.67 for regen.  With Geomery Pattern Off it goes to 18.48 seconds.
There is only a couple second lag from when the regen ends until the hourglass goes away.  This is with a non-CAD, onboard video system.
FWIW,
Anna Wood
SW06 SP4.1 x64, WinXP x64
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
www.auerprecision.com
Thanks to all of you for taking time to help us out here. I'm a little reluctant to even bring up the topic and compare SW with WF. Please believe me that I would like nothing better than to make SW work.
Perhaps I did not make myself clear, but we already have 2 seats of ProE WF 3.0 (we've had ProE for perhaps 6~8 years) the whole reason we looked into SW was to save money. As I explained, the maintenance alone for ProE is 60% of the total cost of SW including training and maintenance. We need training for WF 3.0 because frankly, we don't know the program as well as we could because it's too new. That would only add more money to the cost of operating ProE... From a monetary standpoint it's a no brainer. However, our products are very heavily biased to pattern heavy geometry and we ran into this slow regen issues.
To give you an example, the drawing of this part alone takes something in the neighborhood or 30 seconds to load with SW. The same drawing in ProE loads instantaneously. The solid model regens are not quite so slow in comparison, but the graphics engine of ProE seems to handle these things more efficiently. I've spoken with the reseller again and he assured me that SW can perform at par with WF 3.0 and their resident SW expert will come to our office later this week to show us how to do it. I hope we get the results we want so we can implement the migration.
Thanks again for the input, suggestions and all the time you've spent on this. BTW, how can I post those screen shots of SW? I did a print screen and pasted the pictures in a Word document, but I cannot figure out how to paste them onto a post like this one. I'd like to show you all the exact part that we are dealing with. I'm also concerned about how the performance is going to be with large assemblies... I hope it all turns out OK. I know that I'd love to use that frameing or weldment feature of SW. As far as I can tell WF does not have anything like that....
Why not considering Solid Edge? It rocks!
Solid Edge V18 SP6 on WinXP SP2
Silver92b ... See FAQ559-1100 and FAQ559-1177 for posting images and files.
Please let us know the outcome of the VARs visit. I'm betting that SW is able to match, or beat, WF3.
Gildashard ... that's good to hear, but I've not seen anything to confirm it. I'm just going by what I've read in these threads & personal experience of large patterns slowing things down, but have never seen definitive camparisons. If you (or anyone else) find any, please post.
cheers
I can't find the post....it might have been another forum. Need Heckler to respond as he has alot of Pro/E and Swx experience.
Basically it was large patterns getting into over a 1000 instances. It brought all the cad programs to their knees.
Jason
It seems that most of the people answering your questions are solely SW users.
I work with both softwares and the truth is very simple.
Performance wise,SW cannot be even compared to ProE.
This is even more true for complex plastic parts (Let alon SW weaknesses in surface area)
If yoy want to continue to work with SW you will have to accept it.
However I would strongely recommend going back to ProE.
[quote Anunzio]It seems that most of the people answering your questions are solely SW users.
[/qoute]
Well, I thought that might be the case. But I had hoped that it would not be so....
[quote Anunzio]
However I would strongely recommend going back to ProE.[/qoute]
We do not have complex plastic parts (other than parts with many patterned features) and we do not deal with surfaces either. But so far the parts we have created with both softwares present considerable differences so far... We researched this project as well as we could. From all our conversations with the resellers as well as with SW users, we believed that SW would definitely match or surpass ProE WF 3.0 in performance. Alas, that has not been the case so far. I hope that the SW expert who's coming next week can make it happen. Otherwise we'll have to stay with ProE and pay the higher price.....
No...I remember that cube assy though. This was just a bunch of users comparing linear patterned holes and rebuild times. You remember that question that pops up from time to time when an Autocad user tries to create perforated wire mesh screens or something and brings his computer to a halt when the patterned holes get into the 1000's.
Welcome Anunzio...As a first time poster....do you care to share some screenshots and rebuild times you've experienced? What kind of features give you trouble? I've done some fairly complex parts with around 500 features...curves and surfaces etc. with not too much trouble. Plus there are some great examples like Mike Wilson's Scooby Doo and Mach 5 models. Be interesting to see those modeled in other cad programs....it would sure give a good comparison of rebuild times.
Mike's site:
http://www.mikejwilson.com/solidworks/solidworks_files.htm
Jason
Wasn't SW initially started by some ex-PTC employees?  Or is this just a rumour?
That cube test has been around for awhile, and depending on who is doing the test will depend on who is the best MCAD.  If you went to the link posted above, there are 2 assembly cube tests:
Pro/ENGINEER Wildfire vs. SolidWorks 2003
Solidworks 2001Plus over Inventor 5.3
But if you go to the Pro E site, there testing beats SW:
http://www.ptc.com/WCMS/files/30441/en/30441en_file1.pdf
It may sound like a joke, but you might want to try and make some changes to the part at the top-level assembly and see how your system performs.  Open it resolved, not lightweight, change the radius, etc.  You can make a few changes to the system options, and see how it affects your performance.
If you want to try it, download a 1.1MB zip here:
http://www.mooload.com/new/file.php?file=files/050706/1152112343/Flores_Solidworks_Cube_Test.zip
Also check out Matt Lombard's site for descriptions of the options.  He noted the options that can affect speed or file size with a red star:
http://mysite.verizon.net/mjlombard/
Rules of Thumb > Tools Options for SW2006
Flores
SW06 SP4.1
There are enough 'my cad is better than your cad' posts in this forum.
Bottom Line. Solidworks is a great package. They all have strengths and weaknesses.
If you want my opinion, you can get a screaming processor, a ton of ram, a high end graphics card, an x64 system, and a huge monitor for less than the price of a seat of any of the cad packages. I think you should be complaining about your computer and not that SW is slower than that other package.
RFUS
This is not about which software is better or about how bad or good my computer might be. We've signed a PO for 2 seats of SW and we are now experiencing some problems or issues that makes us think we've made a mistake and we might have to absorb the price of this product as well as pay the ProE maintenance fees....
Any luck with the suggestions provided?
I would seriously give thought to some computer upgrades. Your setup may be working well with Pro/e but not Solidworks. A different graphics card may help with the graphics delay. I noticed the same thing in UG....there's a delay when creating this pattern at the end as it refreshes the graphics. The difference is in UG you can see it happening as the faces are popping up all over the place, in Solidworks it does show you that, you just wait til it's done.
A few seconds can add up.....but I would give a more in depth look at other features in Solidworks that may save you time elsewhere in your work. I never used Pro/e but from what I've heard, the Solidworks workflow is faster so that may offset any rebuild or graphics advantages that Pro/e may have.
Jason
rfus ... if Silver92b upgrades his system, that will also increase the speed of WF3 ... so no net gain!
Also he isn't complaining about SW, just stating that he is disappointed with it's performance, when compared to WF3.
Silver92b ... Have you had a chance to "fine tune" the options per smcadmans suggestion? (Matt Lombards site).
Are you able to post the "offending" file (for downloading) so that we can investigate & compare times?
BTW, where are you based?
cheers
CBL..Maybe the use of the word 'complaining' was a little harsh. Sure, WF3 may rebuild a pattern feature quicker, but the point I was making was that in my realm of time I feel no difference between one second versus two seconds, but really feel the difference between 2 minutes versus 4. Gildashard touched upon my point. I work on 3.6Ghz and 4.2Ghz systems with Quadro3450s, and it drives me nuts when I try and work on on the same project on a 1.8GHz Laptop. I feel like I'm wasting my time.
Silver92b..... You did not make a mistake. I started on ProE. There are things that will drive you nuts about SW if you sit in front of it as much as a lot of us here do. But there are things you will not be able to live without once you master it. An optimally configured workstation is the key to long term success with SW. That was my only point.
RFUS
There are several "experts" here trying to help you out, and some have taken the time to model a part similar to what you are looking for, but we do not have the complete picture yet.
If you look at the number of posts this thread has generated, you will see that many members STILL want to help you even though you haven't posted an image/screenshot that better depicts your final result, or the file itself.  There is more than one way to skin a cat, and someone here might be able to recreate what you need in a different manner than the other "expert".
Flores
SW06 SP4.1
Thanks, we're working with the reseller's expert right now (as I write) to optimize the systems. I tried posting before but there is some problem with my internet connection. I'll try to upload the files in question ASAP.
Wow, this is quite a legitimate thread.  I'm sorry for laughing earlier--the first posts had the dubious marks of the typical drive-by Molotov cocktail--such a tired tactic.  So you certainly didn't need my mocking of the situation.
After reading the progress of this thread, I was about to suggest the upgrades to the computer system as well.  Since SolidWorks is quite dependent on the graphics card for smooth performance, I would disagree with CorBlimeyLimey that an upgraded system would equally benefit the WF3 installation.  It could, but I think the benefits would be much more drastically seen by the SW installation.
Also, try smcadman's suggestion of making a tweak to the upstream geometry.  I find that this sort of thinking will often force a more complete rebuild of the part and sometimes change the rebuild time from that point onward (strange, but I've been with SW since 1997 and have seen lots of oddities).
Otherwise, I don't have much to say with the ProE stuff.  Of course, I do a lot of plastic part design with complex geometry and have had great results by sticking to logical building practices.  I also have a client who--after seeing my work and the nature of the parts I create--is going to ditch ProE for SW when he can find the time to learn the new interface (cost issues are a big factor).  However, some folks can use knives better than others can use guns.  It's certainly tough to find true apples in comparisons of this sort.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
I looked in the links provided but have not had time to dig into them to implement changes. I'll try to upload the files ASAP. We are in the proverbial swamp ful of alligators right now.... We are located in Marietta, GA North of Atlanta.
I made the part like the picture above with 870 holes, 58 around and 15 down. I got around 30 seconds with geometry pattern, 75 seconds without. The fastest way i found to do it was by making the part as though it were one ring with a circular pattern of the 58 holes, and then doing a liner pattern on the ring as a body and then a combining them... 5 seconds.
Large patterns in sketches can cost you a lot of time. So can previews, surface fills (shut off surfaces), Offsets, In-context updates, large assembly rebuilds, and so many other things....But just think.....while your sitting there waiting you can hang out on eng-tips. This is where dual monitors is key!
RFUS
I know I'm a little late on this thread.  But I thought I would add my two cents worth.
I use pro/e 2001 and SWx 2006 on the same machine and often at the same time both at work and home.  My home computer is configured the same as Silver's with the exception of the graphics card....Nvidia Quadro4 750 XGL.  Although our graphics cards a few years old they're still top end performers.  I do not notice any performance differences between my home computer and works....even though my work computer has the forced network security processes that eat away the resources.
I would look at the differences of how you're modeling the parts in Pro/e and SWx.  The core modeling engine differencs could account for the calculate feature creation and rebuild times.  Also, remember you're new to SWx thus do not know all the suttle ways of making SWx perform at its best.  Were you using simplified reps or family tables with your pro/e models?
Hang out on this site and you will learn a lot of advanced tips and techniques.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Quote (rfus):
RFUS
I love the dual monitor thing... I'm going to buy myself a new Mac Book Pro and make it a dual boot with WinXP. I'm going to run the SW in that machine too.
Silver92b,
I just downloaded your part to my work computer.  System specs are below.
From my local desktop, the file opens in about 1-2 seconds. After a crtl-q regen and check of feature statistics I show 5.64 seconds for a re-build.  There is only a couple second lag for the hour glass to go away after the regen.
I also run my system with verification on rebuild switched to on.  Which in general will slow the system down as it goes through a more thorough check for errors in the re-build process.
It was essentially the same open and reload times whether I was in my 32 bit SolidWorks or 64 bit SolidWorks.
This is vanilla SolidWorks with only a Spaceball 5000 running in the add-ins.
Anna Wood
Silver - I downloaded your model and did some modifications.  It's a large model but it didn't impact the performance of my work machine.  I also have a nice size assembly running at the same time.  You might want to reload SWx or run SWxRx
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
Silver92b,
Do you usually work in wireframe mode?  I ask that because your model was saved as a wireframe.  In SolidWorks, solid mode will work must faster.
I seem to remember when I used ProE back about three/four years ago that it worked better in wireframe mode.
You guys with more experience with both systems, is this a valid observation?
Anna Wood
I would think so--especially from how SW deals with the display-end of things.  I always marvelled at how well the solid shades were rendered in SW way back in '97.
Jeff Mowry
OK, the model itself was not too bad to regen or load. The drawing was more of an issue. I uploaded it, but I'm not sure I copied the complete URL this time...
/060706/11522http://www.mooload.com/new/file.php?file=files20717/CP-Drum.SLDDRW
Try loading that file and working with it.
BTW, the last SW install in my coleague's machine works much better than before! I'll install the new SW in my machine tomorrow.
Thanks for your help everybody!
Check out SBaughs  FAQ559-488 for "How do I do a clean uninstall & reinstall of Solidworks?" before re-installing SW.
cheers
OK, here's the latest update. We reinstalled SW in our machines. I followed instructions as per your valuable advise :).. I had to hack my computer to get into the registry, but I managed to get all references to SW and Edrawings after uninstalling them with the windows control panel.
The good news is that the programs are running much better and faster now.
I checked my machine and it has a Xeon 3.06 GHz and 1.5 GB of ram and has the Nvidia Quadro4 980 XGL withe the latest drivers. I'm running WinXP professional with whatever service pack was available the last time our IT guys were here...
My coleague's machine is older and has the 2.0 GHz, with 1.0 GB ram. Although he has the same video card I have, he is running with Win2K....
SW is still a little clunky compared with WF3.0 in some respects, but we are going to keep it. We might have some issues with our network policies and there might be processes running that we know nothing about and are using resources, but we can't do much about that now :P
Thanks to everyone for your help and your patience. I'm sure you'll hear from me again as I will undoubtedly need more help in the future ;)
Thanks again
That's great news. Thanks for the feed back. thumbsup2
cheers
Take note that Win2K will not be supported for SW2007, so you will likely need to upgrade the OS on your colleagues computer.
http://www.solidworks.com/pages/services/SystemRequirements.html?PID=252
Also with larger files or assys, the /3GB switch will also help performance.
http://www.panoramafactory.com/discus/messages/17/313.html?1057432320
cheers
Another thing I noticed when someone mentioned your model saved in wireframe mode. Go to "View/Display/ and toggle on "Draft Quality viewing (something like that)" This should speed up wireframe or hidden line viewing.
If you don't see the option...you may have to customize (bottom of menu) to add it.
Jason
