LS-DYNA hex element
LS-DYNA hex element
Does LS-DYNA support 20 noded hexahedral elements?
Running the exact same simulation with linear (8 noded bricks) works fine, but after giving the elements midside nodes, the all quadratic bricks essentially are ignored by LS-DYNA even though they exist in the input file (IE the part with the 20 noded hex doesn't exist at all in the sim).
I'm using the explicit Central difference method as the solver with ELFORM =1 (Constant Stress elements).
Any help with this would be greatly appreciated!
RE: LS-DYNA hex element
I should add that I have only ever used the ELFORM 1 hex element.
