ASME 80:10 Flanged and Dished heads
Where in the Code can I find the dimensions for 80:10 Flanged and Dished Heads ?
I know the outside radius of dish sould be 80% of the outside diameter of the Head and the Inside knuckle radius should be 10% of the outside diamenter of head.
But I need the code support and I can't find it.
thank you!!!
thank you!!!
RE: ASME 80:10 Flanged and Dished heads
http://www.pveng.com/Charts/Charts.htm
DB
I am not really sure what your question is, but 80:10 heads have been around for a long time.
They are commonly applied in cases where the material cost is very high (e.g. titanium, C276 etc)and an optimum head design (thinnest head) is desired
Contact these people:
h
More good info on:
http://www.brightontruedge.com/pdf/80-10.pdf
tell us more about your project....
Why do you want an 80:10 head for your vessel ????
-MJC
Steve Braune
Tank Industry Consultants
www.tankindustry.com
