PCB connector for fast-on IGBT terminal
I'm looking for a fast-on connector which could be adapted on one side to a standard IGBT 2.8x0.5 mm terminal, and on the other end to a PCB.
Has anyone ever heard of this ?
Thank you in advance
RE: PCB connector for fast-on IGBT terminal
http://w
How about making a simple jig that holds them all in position that you drop on the boards during production.
You could use phenolic or some other plastic. Find a place that will route them on an xyz router, or a water jet cutter.
Or you can design a circuit board with no traces that is just the right size to jig your connectors then just have a board house pump out 100 or two that your assembler can drop over the connectors before wave soldering.
Keith Cress
http://ww
