fluid mechanics
fluid mechanics
fluid mechanics
simple question.
How do I calculate the velocity of water leaving a tap of characteristic length 0.001m.  I know the static and atmospheric pressures.  I also know density and height.  I guess I have to use
velocity x density x characteristic length divided by viscosity
I know this equals the reynolds number and was hoping I could rearrange the formula but don't have the viscosity or Re.
Can I do it another way?
RE: fluid mechanics
If its not a homework assignment then it should be fairly easy to find the viscosity of water. If your temperature is in the neighbourhood of 15 deg C == 60 deg F then you could use 1 cP
Best Regards
Morten
RE: fluid mechanics
we know velocity = flow rate / fluid flow area (i.e 22/28 * d2), where d = pipe inside diameter.
you collect fixed amount of water eg 10 lit. you note down time required to get 1000 lit. Say time required = 20 second
so flow rate = 1000 lit = 1 m3 / 10sec = 0.1 m3 /s .now you divide the flow rate by flow area , you will get velocity of water.
Pawan kumar (chemical engineer)
RE: fluid mechanics
Maybe i didnt read the question close enough Pawan Kumar is right. Forget about the Re and do something like the suggested.
