CI and CS Valve body
There is an old valve body lying in the scrap yard. Body marking indicates 125 24" WSP. It appears from "125" that it is #125 CI body. But is there any other way to confirm the body mterial as CI or CS. We do not have any material spectoscope or any thing fancy. This body can be cut if required as it is already waste.
Any ideas.
Any ideas.
RE: CI and CS Valve body
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
