Adhesive for bonding inox steel
Can anyone suggest me an adhesive for bonding inox steel? Adhesive would work in high temperature conditions. Joint strength will be important, I am looking for a simple method of making structural joints without welding.
Is there, in an Internet website, a company that produces this type of adhesive?
Many thanks in advance.
Eng. Antonino Nicosia
Aeronautical Engineer specialized in Fluid Power field.
my website: web.tiscali.it/aeronavigandosulweb
(in the future there will be many programs about fluid power problems, thermal and structural problems)
RE: Adhesive for bonding inox steel
inox is called in English stainless
Epoxy-based adhesive would work up to ~ 200 °C.
http://www.aerospace.henkel.com/hightemp.htm
For higher temperatures, you should consider brazing. For example, here are some silver brazes for stainless steel:
http:
Cory
