How good is Sharepoint?
We are in the process of evaluating different PDM software. Just how good and stable is Sharepoint with the handling and collaboration of CAD information?
Any comments will be greatly appreciated.
Solid Edge V18 SP5 on WinXP SP2
RE: How good is Sharepoint?
Sharepoint/Insight is set up to be a departmental document control system. If you plan on using it for company wide data management, look elsewhere. Since you're running v18, you may want to give Team Center Express a look.
--Scott
For some pleasure reading, try FAQ731-376
Thanks for your response. Lets say I only want to manage design data and I want to present this information in a simple manner to other departments.
Solid Edge V18 SP6 on WinXP SP2
If ONLY your department is going to be authoring the data and maintains control of the Sharepoint database,
If you ONLY want to provide others with the ability to view your Solid Edge data through a web-type interface,
then Sharepoint/Insight will work for you.
But, if you want other departments to view in-process work, and have approval authority, and be a part of the work flow, then Insight will probably not be the effective tool you're looking for.
<Insert shameless plug>
If you need a consultant to look at your data and give a good recommendation, I can help further.
www.wertel.eng.pro
Of course, I'm always here at eng-tips to help as much as I can.
<End shameless plug>
--Scott
