Vessel Drafting
Vessel Drafting
I don't understand how i have to do to change unit system.
I've got autocad 2006
thank you
thank you
RE: Vessel Drafting
Make certain that you are logged in as Administrator to the computer;
Find file "vdpsetup.txt" located in the VDP folder, check the file properties and specify that it is NOT "Read Only";
Another copy of file "vdpsetup.txt" may also be located in your AutoCAD directory. Rename this file as "vdpsetup.txt.bak". Then restart VDP.
You should now be able to set the Drafter setup to SI units and have this retained. If you continue to have problems with this issue write to support@codeware.com.
Tom Barsh
Codeware Technical Support
