ASME VIII Div 1 UG-34
Hi all,
Referring to sketch j in fig UG-34, the calculated flange thickness 't' is shown from the gasket contact face to the back of the cover,however,the thickness of the flange where the bolt holes pass through appears thinner.  I have calculated 't' using formula 2 for both operating conditions and gasket seating and have a min result of 1.5in. Does this figure apply to the thinnest part of the flange?
I have a copy of another company's calculation which indicates that 't', where bolts pass through, conforms to the formula on page 35 - when cover plate is grooved for a peripheral gasket.
Bit confused!  Any help would be greatly appreciated.
Thanks in advance.
Graybags
RE: ASME VIII Div 1 UG-34
As a flat cover has its maximum stress at center, thickness t of the cover is as represented in fig.UG-34(j).
And the other company's calculation appears to me correct: the formula for fig.UG-34(k) may also be used to check the thickness of the outer rim of the cover.
prex
http://www.xcalcs.com
Online tools for structural design
