help: Mex error
help: Mex error
Hi all,
I am new to Mex. I tried to compile a fortran code.
I use the following simple fortran code to test.
subroutine return_a(a)
real, intent(out) :: a
a=1
end subroutine return_a
the fortran compiler is Compaq Visual Fortran 6.6. Matlab is 7.2.0.232 (R2006)
In matlab command windows, I typed
mex -v return_a.f90
Then I got the following error message
This is mex, Copyright 1984-2005 The MathWorks, Inc.
-> Default options filename found in C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R2006a
-> Options file = C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R2006a\mexopts.bat
MATLAB = C:\Program Files\MATLAB\R2006a
-> COMPILER = df
-> Compiler flags:
COMPFLAGS = /fpp:"/m /SC:\Program Files\MATLAB\R2006a/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed
OPTIMFLAGS = /MD -Ox -DNDEBUG
DEBUGFLAGS = /MD -Zi
arguments =
Name switch = /Fo
-> Pre-linking commands =
-> LINKER = link
-> Link directives:
LINKFLAGS = /DLL /EXPORT:_MEXFUNCTION@16 /MAP /LIBPATH:"C:\Program Files\MATLAB\R2006a\extern\lib\win32\microsoft" libmx.lib libmex.lib libmat.lib /implib:C:\DOCUME~1\Administrator\LOCALS~1\Temp_lib4621.lib /NOLOGO
LINKDEBUGFLAGS = /debug
LINKFLAGSPOST =
Name directive = "/out:return_a.mexw32"
File link directive =
Lib. link directive =
Rsp file indicator = @
-> Resource Compiler = rc /fo "mexversion.res"
-> Resource Linker =
--> "df /fpp:"/m /SC:\Program Files\MATLAB\R2006a/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed /FoC:\DOCUME~1\Administrator\LOCALS~1\Temp\return_a.obj /MD -Ox -DNDEBUG return_a.f90"
C:\PROGRAM FILES\MATLAB\R2006A\BIN\MEX.PL: Error: Compile of 'return_a.f90' failed.
??? Error using ==> mex
Unable to complete successfully
What should I do to fix it?
Thanks?
a=1
mex -v return_a.f90
-> COMPILER = df
-> Compiler flags:
arguments =
Name switch = /Fo
-> LINKER = link
-> Link directives:
LINKFLAGSPOST =
Thanks?
RE: help: Mex error
RE: help: Mex error
Actually I tried the examples that come with Matlab
in directory C:\Program Files\MATLAB\R2006a\extern\examples\mex\
I typed
mex -v yprime.f yprimefg.f
in matlab command windows, I got the same error message
-> COMPILER = df
-> Compiler flags:
arguments =
Name switch = /Fo
-> LINKER = link
-> Link directives:
LINKFLAGS = /DLL /EXPORT:_MEXFUNCTION@16 /MAP /LIBPATH:"C:\Program Files\MATLAB\R2006a\extern\lib\win32\microsoft" libmx.lib libmex.lib libmat.lib /implib:C:\DOCUME~1\Administrator\LOCALS~1\Temp_lib6184.lib /NOLOGO
LINKFLAGSPOST =
Name directive = "/out:yprime.mexw32"
--> "df /fpp:"/m /SC:\Program Files\MATLAB\R2006a/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed /FoC:\DOCUME~1\Administrator\LOCALS~1\Temp\yprime.obj /MD -Ox -DNDEBUG yprime.f"
C:\PROGRAM FILES\MATLAB\R2006A\BIN\MEX.PL: Error: Compile of 'yprime.f' failed.
RE: help: Mex error
C===========================================================
C timestwo.f
C Multiply the input argument by 2.
C
C This is a MEX-file for MATLAB.
C Copyright (c) 1984-2000 The MathWorks, Inc.
C $Revision: 1.1.4.15 $
C Computational subroutine
subroutine timestwo(y, x)
real*8 x, y
y = 2.0 * x
return
end
C The gateway routine
subroutine mexFunction(nlhs, plhs, nrhs, prhs)
integer mxGetM, mxGetN, mxGetPr
integer mxIsNumeric, mxCreateDoubleMatrix
integer plhs(*), prhs(*)
integer x_pr, y_pr
integer nlhs, nrhs
integer m, n, size
real*8 x, y
C Check for proper number of arguments.
if(nrhs .ne. 1) then
call mexErrMsgTxt('One input required.')
elseif(nlhs .ne. 1) then
call mexErrMsgTxt('One output required.')
endif
C Get the size of the input array.
m = mxGetM(prhs(1))
n = mxGetN(prhs(1))
size = m*n
C Check to ensure the input is a number.
if(mxIsNumeric(prhs(1)) .eq. 0) then
call mexErrMsgTxt('Input must be a number.')
endif
C Create matrix for the return argument.
plhs(1) = mxCreateDoubleMatrix(m, n, 0)
x_pr = mxGetPr(prhs(1))
y_pr = mxGetPr(plhs(1))
call mxCopyPtrToReal8(x_pr, x, size)
C Call the computational subroutine.
call timestwo(y, x)
C Load the data into y_pr, which is the output to MATLAB.
call mxCopyReal8ToPtr(y, y_pr, size)
return
end
RE: help: Mex error
For some reason my comlpiler is called fl32 and your is df. I used the mex -setup to do the work.
I had a problem linking. The linker could not find my Microsoft supplied "mspdb71.dll". I found it and copied it to my working directory (a hack).
I could not find anything different with your setup. I am supplying my -v output in case you can see someting. I think the two different call names to the comppiler do not matter. I have an older MATLAB version, so maybe mine is behind the times.
You have an odd name for the directory to send the .obj. Maybe this old tool has aproblem with that. You could change our mexopts.bat and execute it. Or maybe just try to move to a directory at a root or at least without spaces in the name. Just to see if this is where the problem is. It seems you are not getting an indication of what the problem is. The .pl is just giving you a fail notice.
>> mex -v yprimef.f yprimefg.f
This is mex, Copyright 1984-2003 The MathWorks, Inc.
-> Default options filename found in C:\Documents and Settings\solarjo2\Application Data\MathWorks\MATLAB\R14
-> Options file = C:\Documents and Settings\solarjo2\Application Data\MathWorks\MATLAB\R14\mexopts.bat
MATLAB = E:\MATLAB
-> COMPILER = fl32
-> Compiler flags:
COMPFLAGS = /fpp:"/m /SE:\MATLAB/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed
DEBUGFLAGS = /MDd -Zi
arguments =
Name switch = /Fo
-> LINKER = link
-> Link directives:
LINKFLAGS = /DLL /EXPORT:_MEXFUNCTION@16 /LIBPATH:"E:\MATLAB\extern\lib\win32\digital\df60" libmx.lib libmex.lib libmat.lib /implib:_lib8531.lib /NOLOGO
LINKFLAGSPOST =
Name directive = "/out:yprimef.dll"
--> "fl32 /fpp:"/m /SE:\MATLAB/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed /Foyprimef.obj /MD -Ox -DNDEBUG yprimef.f"
yprimef.i
--> "fl32 /fpp:"/m /SE:\MATLAB/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed /Foyprimefg.obj /MD -Ox -DNDEBUG yprimefg.f"
yprimefg.i
Contents of 8531_tmp.rsp:
yprimef.obj yprimefg.obj
--> "link "/out:yprimef.dll" /DLL /EXPORT:_MEXFUNCTION@16 /LIBPATH:"E:\MATLAB\extern\lib\win32\digital\df60" libmx.lib libmex.lib libmat.lib /implib:_lib8531.lib /NOLOGO @8531_tmp.rsp "
Creating library _lib8531.lib and object _lib8531.exp
jsolar
RE: help: Mex error
Could you tell me how to change the directory that .obj is sent to?
RE: help: Mex error
set NAME_OBJECT=/Fo
But I see that your line matches mine, so that must not be the problem.
I noticed that your output showed a strange path name for setting LINKFLAGS.
In mine it is
set LINKFLAGS=/DLL /EXPORT:_MEXFUNCTION@16 /LIBPATH:"%LIBLOC%" libmx.lib libmex.lib libmat.lib /implib:%LIB_NAME%.lib /NOLOGO
Notice the simpler /implib path.
You might try finding the mexopts.bat that was generated when you did the mex -setup. Then edit it to either remove the path name you have with the ~ in them, or hardcode the full path name. Double quotes might work to protect the spaces, but if not try the single quote.
Then run the .bat file. Either in your MATLAB environment using the bang oeprator ! or from windows start run. You will need the full path name I think.
Then after the .bat file executes, try compiling and see if the error message changes.
jsolar
RE: help: Mex error
@echo off
rem CVF66OPTS.BAT
rem
rem Compile and link options used for building MEX-files
rem using the Compaq Visual Fortran compiler version 6.6
rem
rem $Revision $ $Date: 2006/01/13 20:56:13 $
rem
rem *******************************************************
rem General parameters
set MATLAB=%MATLAB%
set DF_ROOT=C:\Program Files\Microsoft Visual Studio
set VCDir=%DF_ROOT%\VC98
set MSDevDir=%DF_ROOT%\Common\msdev98
set DFDir=%DF_ROOT%\DF98
set PATH=%MSDevDir%\bin;%DFDir%\BIN;%VCDir%\BIN;%PATH%
set INCLUDE=%DFDir%\INCLUDE;%INCLUDE%
set LIB=%DFDir%\LIB;%VCDir%\LIB;%LIB%
rem Compiler parameters
set COMPILER=df
set COMPFLAGS=/fpp:"/m /S%MATLAB%/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed
set OPTIMFLAGS=/MD -Ox -DNDEBUG
set DEBUGFLAGS=/MD -Zi
set NAME_OBJECT=/Fo
rem Linker parameters
set LIBLOC=%MATLAB%\extern\lib\win32\microsoft
set LINKER=link
set LINKFLAGS=/DLL /EXPORT:_MEXFUNCTION@16 /MAP /LIBPATH:"%LIBLOC%" libmx.lib libmex.lib libmat.lib /implib:%LIB_NAME%.lib /NOLOGO
set LINKOPTIMFLAGS=
set LINKDEBUGFLAGS=/debug
set LINK_FILE=
set LINK_LIB=
set NAME_OUTPUT="/out:%OUTDIR%%MEX_NAME%%MEX_EXT%"
set RSP_FILE_INDICATOR=@
rem Resource compiler parameters
set RC_COMPILER=rc /fo "%OUTDIR%mexversion.res"
set RC_LINKER=
set POSTLINK_CMDS=del "%OUTDIR%%MEX_NAME%.map"
