hot sequence on ct metering
why is cold sequence not allowed on ct metering per power companies/? is it a safty issue or tampering deterent,thanks-bob
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: hot sequence on ct metering
Normally, cold / hot sequencing pertains to feed through meters, not ct metering.
Cold = main disconnect ahead of meter
Hot = Main disconnect after meter
For large voltages / loads, you would not want to pull the in-line meter, without first shutting off the incoming power.
Rick Miell
