Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say THANKS for the forum. The knowledge I gain from your site is invaluable..."
Geography
thermal radiation field around a gas flare in oil/gas field
wale (Mechanical)
19 Jan 02 4:58
Please, is anyone out there familiar with thermal radiation equations around a gas flare in oil/gas field?
I'm working on a number of energy equations but I'm stuck now...
BillBirch (Mechanical)
21 Jan 02 21:59
Try posting to "Chemical safety engineering".
pmover (Mechanical)
22 Jan 02 18:16
Wale,
I recommend contacting flare vendors (Flaregas, Callidus Technologies, etc.) and get there input.  The two vendors stated are familiar with industry standards and can provide you the needed information (they provided me the needed documentation).
Another source of information is API (American Petroleum Institute) Standard 521 - Guide for Pressure-Relieving and Depressuring Systems.
With regard to the thermal radiation equations, establish the limit of total radiation/intensity (flare+solar) at the base of the flare and a specified radius (i.e. 150') from the base of the flare.  The flare vendor will provide this data (radiation levels vs. distance chart), based on gas moleweight, flow rate, temperature, etc.  The flare height will be determined by the radiation level specified at ground level and wind speed.
I trust this helps.
Good Luck
pmover
cougarfan (Mechanical)
4 Feb 02 8:52
I agree with them - contact a flare vendor - they do this ALL day long......
3 May 02 16:11
If you haven't contacted a flare vendor, try API 520 appednix has some information.....
Close Box
Join Eng-Tips® Today!
Join Us             Close
