Backlash
Backlash
Backlash
Is there a standard for pin to pin dimension and/or backlash when designing spur gears?
RE: Backlash
there are hundreds of standards and tolerances,agma,bs,iso and din just to name a few, each standard has classes and each class has tolerances within that class, i know this won't help you a lot but it will show you how there is no sraight answer to your question
RE: Backlash
The size over pins is calculated from the known tooth thickness (and another gear data). The tooth thickness is selected/calculated for desired backlash. Backlash can be taken from standards for desired gear precision grade or simply used as a known value which works OK for the gear's application.
Do not forget that tooth thickness has also tolerance, which depends on the precision grade...
As lbmakem mentioned - no simple answer to your question.
RE: Backlash
Dudley's Gear Handbook lists "Recommended Backlash Allowance for Power Gearing" for a number of pitches and center distances.
RE: Backlash
http://webstore.ansi.org/ansidocstore/dept.asp?dept_id=125
ANSI/AGMA 1003-G93 (R1999) - Tooth Proportions for Fine-Pitch Spur and Helical Gearing
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: Backlash
Just want to add that AGMA classes give fluctuating ranges for the variation on the tooth profile such as the total composite error and tooth to tooth error etc. But all these tolerances (except the reduction from tooth thickness and the tolerance on tooth thickness) are AC (alternating)values with analogy to electricity. The DC value is measured by the testing radius of the gear when meshed with a master gear or the dimension over pins. There are no standard values for the DC part of the gear dimension.
RE: Backlash
Dudley's gear handbook suggests backlash typically for general machine practice. Genrally it boils down to .015/dp to .040/dp. But if you need really quiet gears your backlash needs to be less than above values. As I said if you are designing gears for normal practice above values will work good.
Ravi
