Pressure drop in half pipe coils
I am looking for some articles or equations to calculate the pressure drop in half pipe coils that make up a reactor jacket.
RE: Pressure drop in half pipe coils
I've had good success using the equation in Crane TP410 for more than one bend.  You have to calculate two diameters.  One from 4 x hydraulic radius to use for the Reynolds Number and the other for equivalent flow area of a round pipe for use for the velocity terms.  I may have more input on this tomorrow when I'm in my office.
Good luck,
Latexman
In my Crane TP410 (25th printing in 1991) the derivation of their "Resistance of Bends" equation starts on page 2-12 and is presented in final form in Equation 2-20:
KB = (n-1)(0.25.fT.Pi.(r/d) + 0.5.K1) + K1
n = number of 90o bends
fT = fully turbulent Darcy friction factor
r = radius of bend
d = diameter of pipe (I use 4 x RH for 1/2 pipe)
K1 = K of 1 bend from Table on page A-29
r/d        K1
1          20.fT
1.5       14.fT
2          12.fT
3          12.fT
4          14.fT
6          17.fT
8          8.fT
10        10.fT
12        12.fT
14        14.fT
16        16.fT
20        20.fT
When I put KB into a pressure drop equation I use d = equivalent flow area diameter, square root of (4.A/Pi), so the velocity is correct.
It has been field tested many, many times by me over the years.
Good luck,
Latexman
I will give it a test against the method suggested by 25362 and let you know how they compare.
