Measuring Pressure Gradient Across Valve
System consists of a cylinder (piston), pressurizing fluid through a mechanical flow control valve in the restricted direction, (metered flow in 1 direction, free flow in oppositte direction), pouring into a resevoir exposed to atm press.
The system was tapped with two pressure gages immediately before and after the metered control valve. Operating the piston gives me a gage reading of 1000psi just before the valve and 0psi just after the valve. I'm assuming the 0psi is due to zero back pressure (gage) at the resevoir therefore the pressure head is in the form of (V^2)/2g.
Comments appreciated.
Now if I apply resistance to the outlet hence backpressure the gage after the valve reads 800 psi. So a 200 psi (1000-800) drop occurs across the valve according to the gages.
Without the backpressure one might interpret the pressure drop as 1000psi. With the backpressure, one might interpret the drop as 200psi. If a cap was used on the outlet to provide infinite resitance both pressure gages would read the same 1000psi, right? So with an added resistance to the outlet (backpressure) I'm assuming the difference in gage readings give me the pressure gradient across the flow valve. The various gradients just represent different flows with delta 0psi corresponding to 0 flow. Is this correct?
RE: Measuring Pressure Gradient Across Valve
