Costs / Bogey Numbers
We have a plethora of small steel weldments, ie:
knee braces, usually 3x 3x 3/8  x  4 foot overhang
Short pipe stands with end 1/4" plates, 4'WF usually 4 ft high
6 ft sq low level platform step-ups about 21" high
All are C.S. and primed / gray spray epoxy
Need is to rough cost for domestic fabrication based on poundage
What would be the current cost per pound out of a local fab shop?
Same question if all were hot dipped galvanized?
RE: Costs / Bogey Numbers
Shopper,
I have bought steel here in the U.S. in the past year for the following prices:
GALVENIZED C.S.:
700lb @ 2.11$/lb
725lb @ 2.2$/lb
13500lb @ 1.5$/lb
44500lb @ 1.34$/lb
Non-Galvenized C.S.:
590lb @ 1.61$/lb
I notice you post was a few weeks ago so you may have already purchased, if so, I would like to hear your prices...
