Thermal barrier
Thermal barrier
I am trying to measure the temperatures within an oven with a "Datapaq-logger" which goes within a so called thermal barrier and can travel through the oven. The oven has a temperature of 800 degrees and its conveyor takes around 10 minute from input to output side.
My logger (thermal barrier) can take only 800 degrees onder 210 seconds and I need to extend this capability up to 10 minutes. My question is if anyone knows a supplier who can supply me additional thermal barriers with this capability. maybe I can put my barrier within another vault and by doing so extend the duration.
I appreciate your answers.
cheers
cheers
RE: Thermal barrier
What about cooling the barrier, or placing a highly reflective covering around it?
RE: Thermal barrier
RE: Thermal barrier
cheers
