Lazy AutoCAD LDD?
Lazy AutoCAD LDD?
Lazy AutoCAD LDD?
AutoCAD Land Development Desktop 2i it's what I use and try to access from VB. BUT the preaty easy code like:
Set ACAD = GetObject(, "AutoCAD.Application")
Set app = ACAD.GetInterfaceObject("AutoCAD.Application")
ParcelNumb = app.ActiveProject.Parcels.Count
... takes MINUTES for ~200 defined parcels. In AutoCAD's VBA the same code runs just a little faster (and shoud be) but it's still fare, fare away from being usefull.
I experienced the same on two different ACAD instalations.
Do you think it's normal?
Jan
RE: Lazy AutoCAD LDD?
With the way you are doing it, it is normal. Try using
LDD's predefined methods of managing parcels, it works
fairly well.
