How to learn about "Steel Grades"?
Can someone please give me a low down on the standards for steel grading. I am looking for brief summary. Example there are x systems used commonly, one system uses ASMT as a prefix, the other uses SAE as a prefix etc etc. I will then have furthur questions so please bear with me.
I am a software engineer who has found himself managing supply chain for a manufacturing plant manufacturing "Automotive Parts".
I appreciate your help in advance.
Thank you.
Thank you.
RE: How to learn about "Steel Grades"?
http:
Although after some time you will recognize the more common designations..
Good Luck
