Solvant free Polyeruthan Lining
We are on water project in North Africa and difficulties with the application of Solvant free Polyeruthan Lining.
The Product manufacturer is Goldschmitt
The Product Protegol 32-55 R in 2 component mixing ratio 1 to 3.3.
Support CS Pipe Grit Blasted to Sa 3
Application by hand with Hot Airless Grako machine
Environment: Air Moisture acceptable
             Temperature over 40 degree Celsius.
Difficulty: 48 hours after application the surface present many blisters from various size
