H2S Corrosion in Black Sea
Would like to know if steel springs in equipment about to be put on Black Sea floor will be affected by the H2S in solution in the Black Sea
RE: H2S Corrosion in Black Sea
http:
Cory
I agree with CoryPad, use the NACE document as a guide for suitable material selection. Even stainless spring steels will be questionable in H2S environment. I am not sure if nickel-based grades like Alloy X-750 are suitable for sulfide exposure, but titanium alloys definitely are. I would investigate a suitable titanium alloy and re-design the spring to accommodate it. Renton Coil Spring in the USA is a leader vendor of titanium springs.
